WGB wrote (in the other thread):
You and Des sure have had a lot of trouble with that car's suspension and I offer my sympathy but the answer must be there somewhere.
Is it still down at the front?
Might be a time for another posting ofteh problems and try again with some collective wisdom.
Yeah why not... here's an update.
When the weather heats up and car lifts to normal height... like today... it was 30 degrees and the car looks just about right. The suspension light still doesn't go out, and the distribution valve plate just turns freely with no feel in the detents.
In the cold (Nov and Dec in Melbourne have been pretty much under 25 degrees except for the odd day over 30) the car won't lift and if I load it up with people or freight it will sink at the back, sometimes quite severely and won't self level. Even then after removing the people/freight - thank god I drive this car for the most part solo without passengers- it takes ages (like days, not just a long 1hr drive), but a hot day to bring it back up to normal height.
About a week ago I disconnected the high pressure hose from the pressure regulator and pointed it into the reservoir to double check the pump is providing good volume, which it is, even at idle.
Loosening the hex nut and/or the large 19mm nut on top of the pressure regulator with the engine running doesn't produce much in the way of hydro fluid coming out (I thought there would be copious amounts under considerable pressure) so I have no idea where the fluid is going... If it was going straight back to the tank then looking down the filler into the tank with the engine running I thought there would be considerable motion on the surface of the hydro fluid, however what I see is hydro fluid sitting like a calm pond - no descernable motion whatsoever.
I've been reading a book which came with my car called Aus Model Year 1979 which has a very extensive section on the hydro setup and I can't help but think that the central sphere circuit isn't properly pressurising and thusly the distribution valve isn't able to send the fluid to the required level controllers. The reason the car doesn't sink to the ground is some check balls have come into play and the hydro struts are pressurised well enough to not let the car sink. Where that theory falls apart is that on warm ambient temperature days the car will more than likely lift to its proper height.
As always this is my only daily driven car so any work I undertake has to be able to be done on a weekend and I can't disable the car like I did in October. My next annual leave is in Feb which I intend to spend sorting this out, or looking at springs.
Ian.
