HansKruger
I can understand why DES sold this car, it must be painfully annoying with these continual problems
Regards
Hans
Regards
Hans
Regards
Hans
I thought the hydro system on 6.9s, at least by 1979, was self-bleeding (just drive the car vigorously for a while)? Also when the suspension did pressurise at the front properly, all 5 spheres and 4 hydro-struts behaved as they should, giving the normal 6.9 magic-carpet type ride.
Help?
Ian.
I don't think the problems are "continual" at all??!! Ian, Des, maybe you can shed some light.
I think Ian has only recently experienced issues, and instead of going to a mechanic and getting a$$ raped for several thousands of dollars (cause they won't bother diagnosing, instead just replace everything in the hope it will fix the problem) he's trying to troubleshoot the issue himself.
From what i've seen of B13's 6.9, it's a pretty good example.![]()
You must forgive me then from reading the information here it seems the problems have been ongoing since Des sold the car
It will not bleed by itself, but you can try running it on the high setting and taking it for a long drive, then bring it back to the normal level, assuming it will rise while you are driving it. Try twisting the dash knob to see if you can get the light to come on. Sometimes they need a bit of twisting.
The warning light is always on. I disconnected the cable and there is no feeling again in the distribution valve detents again. Car feels and acts more or less than same as before I changed the pump. New pump output is heaps better than the old pump's. Am reluctant to do anything at the moment incase it drops and doesn't lift up again... might have to wait until I next have holidays because, rather stupidly I now admit, this is my only car...
With the cable disconnected, and not running, what happens when you move the adjustment slide by hand ? Any noise or movement ? Try same with the motor running.
Yes I did that Bill. This pump is rather better, much more flow at idle and from about 1500rpm onwards theres a strong constant flow.
Considering what I had spent and what I had replaced, I was not exactly happy.
