Now I know why I am wary of 6.9s, much as I would like one, can I keep up with all this?
Hmmmmmmmmmm.......................
C.M.
I know if I said what I am going to say on another forum I would be labeled as "6.9 bashing"
But it seems from what I have learnt with these cars from the forums and owning one that it is going to be a continual path of problems and worries unless you spend several thousand dollars to replace everything, struts, spheres, valves, suspension pump etc.. etc.. with all new parts.
That way then you are going to have trouble free motoring for several years.
Otherwise you are going to have intermittent or niggling problems.
Hey maybe there are exceptions to this, but just from what I've seen this seems to be the case.
Don't get me wrong I think the idea, of hydraulic suspension is great, but it has to work, like the Mercedes Benz central locking system, it is clever, rather than using electronic solenoids, it uses gas from the manifold to lock and unlock the doors. I like that, it works, once it is fixed, lines replaced..the little tanks in the doors etc... etc.. it stays working.
I like the ipod, it is a clever and simple to use device, but if it broke every 2 months I would break it for good.
I understand the reality, who can afford to spend $5-10k replacing everything in their suspension with new parts. You could own a Rolls Royce with that sort of maintenance budget.
We live in proper cities with paved roads, not the dirt roads of Africa, I really don't see after driving several Benzes much benefit over a well maintained coil spring car, I'm just not convinced, for all the headaches that can come from keeping something that should stay fixed, fixed.
I am not bashing these cars, I'm really not, I think you just need to be realistic if you want to own one.
