Des buys a new Mercedes
More threads by Des
Des
Des
Australia
Only a guess but 220 - rear door contacts - I would think means the rear doors work the interior light.Bill
Yep it has the little black contacts inside the doors, which activate the interior light. I notice it lacks the rear interior light, just the one next to the rear view mirror.
The 1977 230 I had, had two interior lights, one at the front and one at the back, front doors operated the front light, back light, you guessed it for the back doors, with that you could also switch the light on manually from the switches where the sunroof is normally operated from.
Des
Des
Australia
Dear Michel
Didn't realise you had another w116 till I read that and your sig,
have you posted any pictures of your car?
would love to see
looks like a fairly common list of options there, I guess these would be the same on almost all cars
466 CENTRAL LOCKING SYSTEM
480 SELF-LEVELLING SUSPENSION
580 BEHR AIR CONDITIONER
599 HEAT-INSULATING GLASS, BAND FILTER
625 VERSION FOR AUSTRALIA
220 REAR DOOR CONTACTS
420 AUTOMATIC TRANSMISSION, FLOOR SHIFT
436 ELIMINATION OF FRONT LEFT AND RIGHT AUTOMATIC (SELF-REELING) SAFETY BELTS
Kind Regards
Des
Dear Michel
would love to see
Kind Regards
Des
I have not had a chance to do any posting or taking any pics for that matter.
I bought it on ebay cheap as it was one suburb away.
I took a punt and drove it home.
Jerry did his magic, reparing all the rust and giving it a general tidying up.
So.... on the body side, it's great (except for some minor clear peeling here and there)
The interior could do with a spruce up... and mechanicall it's ok... as they say: "Goes Well"
G
GreaseMonkey
So far Des, it looks like you have been getting the right answers.
The colour is Silver Green, same as my Crayford wagon was, (see other postings for more on that). Often called Thistle Green but that came later, I have an original colour chart which confirms Silver green for the earlier ones.
The brake warning light on yours should be just for parking brake on or fluid low, and if a top-up cured it, you now know, but yes, as stated above, brake fluid can not just evaporate, so you have a leak.
The difference between min and max on most brake fluid reservoirs is the amount neede to go down the pipes to compensate for pad wear, so when it is on min. your pads are probably worn down.
The only other cause is definitely a leak.
Easy to see if the calipers or hoses are wet, but a common culprit is the seal at the back of the master cylinder, so if there is a damp trail under the flange down the front of the booster it is a master cylinder rebuild.
It is always worth flushing with fresh fluid when buying a car with unknown history and then every two years, brake fluid is hydroscopic, meaning it absorbs water from the atmosphere, and the higher the water content, the lower the boiling point, and then one day going down a mountain the pedal will go straight to the florr, I know, I've done it!
All easy stuff to fix though, so it still sounds too good to wreck. Give it a service, brake fluid, oil change, plugs etc, then drive it a while before deciding. It may turn out to be a good daily driver.
Chris M.
Des
Des
Australia
Chris M.
thanks for your reply Chris, been out this morning for a spirited drive, done about 100k's and the brake fluid hasn't gone down.
Going to get my mechanic to give it a look over and see what needs doing and how much etc..
decide then what I am going to do.
J
JoeB
116's are such a nice looking car. For a second I thought you bought back your 6.9
:D
While you are at it Des why not make it a work of art like Pro Hart did with his Bentley?
What style nazi says all the panels have to look the same? A little colour variation never hurt anyone's power output, now did it? I think mid grey and orange would contrast nicely with silvbergrun. Shall we try it and see? :D
Here is the Pro Hart Rolls Royce - use it as a model?
J
JoeB
Michel, I mentioned the 116 to a friend of mine, who has one in his garage (needing repair)
I don't know whats going on with him, because he's had to go O/S for work.
Des.... you need to find an airbrush guy or a few graffitti artists to paint a peace sign or something down the sides now :p
Pro Hart should have never been let anywhere near a Rolls or Bentley with a brush and some paint in his hands...
:rolleyes:
Des
Des
Australia
I don't know, maybe a taxi sign for the roof?
that Beirut taxi look
I would be happy to have Pro Hart (deceased unfortunately) paint my Phantom -
so long as it in BRIGHT YELLOW.
Sorry for diverting your post Des!
Ohhhhhhhhhhhhhh... You just bring it to Jerry.... :p
He'll apply plenty of yellow for you .....:D
WiSeGuYY Des Websites and Links 15
Michel Befitting Sir Des Gumtree/eBay/Facebook Listings 7
BenzBoy One for Des Talking Torque 4
SELfor50 For Des - Karmann Cabroilet Gumtree/eBay/Facebook Listings 6
Michel Local Car For Des Gumtree/eBay/Facebook Listings 5
BenzBoy For Des Talking Torque 6
G A Challenge For Des & Michel! Mercedes W116 18
Michel For Des (and collectors) going cheap Gumtree/eBay/Facebook Listings 1
abl567 Attention Des Gumtree/eBay/Facebook Listings 31
Michel Something for Des Gumtree/eBay/Facebook Listings 5
Michel For Des...... Gumtree/eBay/Facebook Listings 12
Michel The Car For Des - Lord Protector Of England Talking Torque 12
L Mercedes Benz 300 w186 Mercedes W186, W188, W189 and W100 0
B Where Can I Find a Reliable Mercedes WIS Download 2015 Version? Mercedes W126 2
Oversize Mercedes V8 Inlet Manifolds Mechanicals 246
