Des buys a new Mercedes
More threads by Des
Neh, that looks like a blanking plate where the SLS pump goes....
Just as well... remember you loved the hydro setup on the bismark? Its not unlike that... better to be without it.
Des
Des
Australia
I meant that tank "thing" on the front of the radiator, isn't that the same as the 6.9?
yes still have stains on my carpet from the Bismark bleeding everywhere.
Hi Des,
Well yes it does the same thing on both the 6.9 and the 280S... it receives and dries the freon in the a/c system... but its not part of the suspension.
Cheers,
Ian.
Des
Des
Australia
ah cool thanks
I was thinking that was the tank for the suspension.
all good!!
Kind Regards
Des
Yes - forgot that wear sensors were only fitted after 1976 or so and the light is on the right side of the blank bit in the middle.
So it is either
1) Low brake fluid
2) Sticking handbrake release (not uncommon and quickly stuffs the shoes)
3) Faulty brake fluid connection or switch
4) Faulty or shorting switch or wiring to the handbrake release
5) Retro-fitted brake pad sensors with low pads.
Des
Des
Australia
Thanks Bill, I'll check these and report back.
I did notice the hand brake makes a rip sound, like in a normal car when you rip up on the handbrake without using the button to engage it correctly.
Kind Regards
Des
oscar
Riverina Australia
I usually turn the handbrake handle as I pull it, or push the button in on other cars so putting the handbrake on is silent. It's an old pedantic habit I learnt from a driving instructor years ago that said it stopped wear on the ratchet:rolleyes: Just a bit of trivia.
Now, a nit-pic, you know me, it's like a Where's Wally.:D What about the bonnet star, has anyone else noticed it yet. What's it from?
Nup, that's even newer than 126's yeah?? got the little ball thing at the base of the star... i'm probably wrong.. but i can be certain it's not off a 116.
Congratulations Des....:cool:
And welcome back to the fold..
What a find.....;)
Green too :D
Martin280s
Jundiaí, Brazil
It looks like it's off a later car,maybe W124 or newer, but fitted to the original base.
oscar
Riverina Australia
ummm?? is it not from a W116?
Not that it matters Des. Like I said, I love to play spot the difference. ;) But at least you've got one there. My 350 was without a star for a few months before I sourced one. They look so naked without one.
So yeah, I don't know what it's from, it's just not a typical w116 one. I thought the flat base might be right too like Martin says even if siliconed or glued on. It needs the correct star and retaining spring and clip to hold it on. But the star's base is completely different like Cam said.
Des
Des
Australia
yep was out of brake fluid, the reservoir was nearly empty, filled it up, problem fixed.
Took the radiator cap off, all fell to bits, new cap on, she is fine.
oscar
Riverina Australia
That's good news.
The only other thing now is to keep an eye out for the leak. There's simply no other way for brake fluid to disappear over time unless there's a leak. It'll most likely be either a hose or calliper.
Des
Des
Australia
ok yep, thanks, was thinking there had to be a leak somewhere.
I must say, these M110 engines really do sound sweet when you give them the boot, probably more so than the CE, normally I don't care much for non V8 sounds but that BURRRRRRRR of the M110 is really great.
The power is really quite reasonable for such a big car.
116Benz
Forest Lake, Brisbane QLD
Is it Thistle Green or Caledonian Green? Either way, congrats Des, it looks like a bargain buy, I'm impressed. You are planning on selling the CE now? or keeping the 2 of them?
Or, is it Silver Green? What paint code have you got there Des. Maybe I need to go find one myself.....cream paint with red interior? MMMMM.
Des
Des
Australia
861 silbergrün
Probably the second best W116 colour, apart from classic white.
Unsure yet what I am going to do with the cars yet, have just ordered a stack more new parts for the CE so will probably keep that, see how the 280S holds up,
just been out for a bash around the streets, notice a few things,
temp seems to be around 40-60, assume that is a stuck open thermostat, wouldn't really call that an issue as it is better to be stuck open than stuck closed.
when you give it full throttle there is a slight trail of blue smoke behind the car, so must be rings or something like that, not really an issue for now, motor seems strong and pulls well.
not bad really.
116Benz
The smoke could just be valve stem seals, compared to rings isnt a big issue.
WiSeGuYY Des Websites and Links 15
Michel Befitting Sir Des Gumtree/eBay/Facebook Listings 7
BenzBoy One for Des Talking Torque 4
SELfor50 For Des - Karmann Cabroilet Gumtree/eBay/Facebook Listings 6
Michel Local Car For Des Gumtree/eBay/Facebook Listings 5
BenzBoy For Des Talking Torque 6
G A Challenge For Des & Michel! Mercedes W116 18
Michel For Des (and collectors) going cheap Gumtree/eBay/Facebook Listings 1
abl567 Attention Des Gumtree/eBay/Facebook Listings 31
Michel Something for Des Gumtree/eBay/Facebook Listings 5
Michel For Des...... Gumtree/eBay/Facebook Listings 12
Michel The Car For Des - Lord Protector Of England Talking Torque 12
Oversize Mercedes V8 Inlet Manifolds Mechanicals 239
