Testing K-Jet Injectors
In fact I can’t see how you could even do that based on the design of the nozzle!!!
Yes, the advantage of the tester is probably to know when you really need to replace them vs making the assumption.
As I would need 22 injectors, it would get quite expensive if I just replaced them all.
At least they are not as bad as D-Jet or M100 MFI injectors.
Initially, one could check injector/engine running characteristics by loosening one injector at a time on the fuel distributor with the engine running. If you want to go a bit further, use a slave fuel line, fit it to the fuel distributor and the injector that you must have removed, disconnect the switch lead at the side of the fuel distributor so that you have constant fuel pressure when turning on the ignition, and then push down the diaphragm that sits in front of the fuel distributor.
This will then enable you to observe the spray pattern, also if the injector drips, and then repeat the process for the other seven injectors. You'll probably spend three hours or so on this work, but at least you know how efficient your injectors are. Regards Styria
Wouldn’t that flood the engine with fuel & risk a hydro lock?
Mark, that has not been my experience. It seems completely safe and, whatsmore, fool proof. Regards Styria
c107 Carobu Engineering - 560 Dyno Testing Mercedes W126 38
Styria Road Testing the A-Class Road Tests 5
motec 6.9 W116 crash testing Mercedes W116 0
Styria Testing the new s-class Talking Torque 5
Michel Testing the A Class Talking Torque 8
Michel Testing the 350SLK Talking Torque 2
Michel D-Jet, K-Jet, etc... Mercedes W116 8
Styria K-Jet Injector problems Mechanicals 14
S Electronic Injectors Articles 3
S dribbling injectors Mercedes R/C107 7
SELfor50 FS: 1 x M100 (6.9) Modified Intake Manifold & Injectors Gumtree/eBay/Facebook Listings 7
