I'am almost there having stripped out the spheres and struts, replacing the front strut ball joints, installing the struts with new flexible hoses, installing the new spheres all with new copper washers, cleaning the reservoir and filling with hydraulic fluid and running the engine the fun started. The battery was dead and could not be revived so used jumper leads to start engine.
One of the high pressure lines to front left sphere was not tight resulting a big puddle of hydraulic oil. Fix this try again, slight leek back rear.
Raised car and secured drain line connection. All going well now except for dead battery.
Upon further investigation the alternator was not putting out what it should. Removed alternator to be tested by auto electrician (who are a special bread as I will explain later). Tested on test rig worked fine. Bought new battery from auto electrician, need to support local when you reside west of the Hawkesbury.
Home again put it in the car again no output, take it out again back to auto electrician and he would investigate alternator internally. A couple of day later rang auto electrician and he advised the alternator was fine and further investigation would require the car. Home again fitted the alternator, but no charge light on before starting engine, back down to auto electrician in the car with new battery fine alternator.
At the auto electrician it was resolved that there was a break in the cabling between the alternator and the charge indicator light and a Friday afternoon too big task to take on. Took car home, followed wire from alternator to under battery where the new sphere was fitted, big gap in cabling found. Fixed cable and charge light works and alternator is charging. As an electrical engineer if find it difficult to understand why the indicator light failure would stop the alternator from charging. The reason upon further investigation is that the prowler through the light energises the field winding until the alternator is charging. This is why I consider auto electrics strange if the cheer lamp fails the alternator may not commence charging but there is no indication that this is occurring since the lamp that is supposed to show the fault has failed. The moral is check you charge indicator light illuminated after you turn the ignition on but before the engine starts.
Now the only remaining issue is the front did not appear to rise and fall when I used the high/normal control. Checking in the engine bay the connecting rod between the front level control and torsion bar has disappeared. I am sourcing a new connecting rod but am mystified how I SET THE HIEGHT OF THE CAR. My service manual does not have section 40-315 can any body HELP.
