Disco Panzer
More threads by ProfessorExperimental
ooouuuuu. Someone else with my rebuild mindset!
Thanks for posting all of this by the way, it's really good to have input from someone with more than my (nearly non-existent) IRL experience with Benzes. So much US-centric or downright confusing information on some things available online, very little on others...
Ahh ok. I would like to rebuild the 3 speed even if I do end up doing the engine swap (I'd eventually rebuild the m116 too, since it's original to the car as far as I can tell. I'd just keep them stored in case of future preservation-of-automotive-history desires).
I'm conscious of the march of time and impending scarcity of experienced rebuilders so I was ready to do that now regardless, but I guess I may have already missed the boat.
Obviously at 5k on top of the cost of a 722.3 trans if I want to do it properly (and before installing it rather than down the track) the 5L conversion option would be better served with an uprated T5 or so, since originality is out the window anyway...
<pondering>do some of it right, some not... or do none of it right...</pondering>
There are rebuilds and there are reabuilds too.
A simple reseal (all some rebuilds are) is maybe $3k. Most would replace the clutches too. Bands and torque converter are often extras. I wanted it all done properly as I don't want to have to take that transmission out again.
Yeah I'd do it the same way as you. That engine and transmission both I'd want to put back in the car only once ;)
365g/min = 487cc/min assuming a middle-of-the-rd specific gravity of fuel of 0.75g/cc.
If anyone has measured a D-Jet (ideally 117.983) fuel injector's flow rate I'd love to know if it really was within 10% of 490cc/min. If so that'd be fantastic news as 500-700cc injectors are by far the most common size range, and by the look of them unless they have a very specific angle spray pattern they're the same size as all the bosch-derived injectors I've seen up to the 90s.
So, not strictly $3000 a set to replace...
Eg denso 195500-1378 for mx6, 550cc/min and quite well regarded: same form factor, low impedance and about $60 for a set of 4. Just needs a short hose clamped onto the top feed rail fitting.
Went to visit Team Global Express today. Picked up a nicely wrapped present from a wrecker in Victoria. Nothing special [sighs forlornly at the M117 ECE that might have been], but maybe I can make it something useful...
