Testie
I think I have tried everything but am I missing something?
The "eye ball" vents when open blast hot air. The dash levers make no difference. So with the air conditioning on , all 4 levers down, fan on 3 ,you can get fresh air to the other vents but not refridgerated. The condenser and dryer have been replaced and new gas.The clutch is definitely coming on and the hot water tap is closed. I have fitten an extra termo. fan in front of the radiator to help cool the air conditioning radiator but that has not helped. I will have the gas pressure checked tomorrow but in the mean time is there another heater pipe that enters the cabin. If not how are the "eyeball vents" getting hot air? I only have one tap and one set of vaccum pipes, but it does appear to shut the water off. If open the dash levers it will cook you in seconds, great if it was snowing but it isn't at the moment.
Any help appreciated.
Col.
Col.
