W107 Flasher canister
More threads by Eagle Bill
Hi EagleBill, on the 116s, the flasher unit is located below the instrument panel, but it is normally accessed by removing the covered knee pad and the large black plastic heating/cooling distribution panel behind the knee pad. It is normally located by four self tapping screws.
I would imagine that you would have the the very exact same situation with your car, but access is probably even a little more difficult as the 107 is a smaller car physically. In order to actually get to the unit itself, you will probably have to lay on your back, face close to the brake pedal and legs up in the air gripping onto the back cushion of the front seat. One of the jobs not quite so nice. The flasher unit itself is black, of rectangular shape and has a three pin connection (should have) that fits into another larger connector. Sorry no pics., and if others have more details to add, I am sure they will. Regards Styria
Terqel
MELBOURNE
Hi, this response is a bit late, I have an 1981 107 and the canister is directly behind the instrument pod. You can't miss it. if you are not sure put the hazard lights on when you remove the pod. My instruments are all electric but the 350SL will have a mechanical oil gauge so watch the oil when you disconnect the line. P.S. if you are looking for a louder flasher sound you probably won't get it. They are very quiet even the replacement ones. I used a cable tie to pull the canister back to connector which helps the sound to resonate.
T 280SL W107 flasher can location Mercedes R/C107 7
motec 6.9 Will never buy a W107 Mercedes R/C107 20
Oversize New W107 FB Page Websites and Links 1
260ebenz Something for W107 fans Mercedes R/C107 6
6.9forever R/C107 not W107 Mercedes R/C107 3
Styria Tribute to our W107 Websites and Links 0
WiSeGuYY UTE from w107 slc Exteriors and Body Repairs 13
Oversize The best W107 video??? Motorsports 12
garrye w107 custom exhaust Mercedes R/C107 18
motec 6.9 W107 Mercedes R/C107 3
motec 6.9 w107 with m120 Mercedes R/C107 1
motec 6.9 w107 big block Mercedes R/C107 0
Oversize W116 & W107 pics on Youtube Websites and Links 2
garrye W107 SLC Side skirts Mercedes R/C107 14
S w116 parts on a w107 Mercedes R/C107 3
T hardtop SL W107 Mercedes R/C107 3
C Which W107 model? Mercedes R/C107 14
B Wtb: W107 sl parts Mercedes R/C107 0
J W107 Repairs etc link. Mercedes R/C107 0
smueller99au W107 350SLC engine mounts Mechanicals 14
J W107 Subframe Recall Mercedes R/C107 3
J Keyless Entry for W107! Mercedes R/C107 3
Des The daddy of all W107's Mercedes R/C107 33
