Update on my 280SEL and 350SE
More threads by Andrew280SEL
Andrew280SEL
Tasmania, Australia
Hi guys,
I figured I might give a bit of an update of where I am with my two W116's, since I've been inactive for quite a while before coming back on last week.
Those of you from the ORG site may remember that my 560,000 km 280SEL, while a beautiful car in appearance, had a couple of annoying mechanical problems.
Mainly because it was a dog to start when warm, and because of a bad vacuum leak somewhere in the inlet manifold, idled terribly under load (i.e in gear). Not to mention the terrible fuel fumes as it ran incredibly rich at the same time.
Now it was only recently I got around to being able to do any actual work on the cars, so the week before last I acquired some new K-Jet fuel injectors and seals for the 280.
The old injectors were very suspect seeing as the car ran so rich and started terribly warm, so naturally I was expecting a big improvement after installing them.
I've never done an injector job on these or any cars before, but the K-Jet job is surprisingly simple and easy.
So anyway I installed the new injectors, and after doing all the checks for fuel leaks and making sure everything was fine, I took it for a spin to town.
As I said, I expected a big improvement, and sure enough there was.
Despite still having a bit of a dodgy idle under load while "crawling" (i.e moving into a parking space) due to the vacuum problem, the car starts FIRST time EVERY time now, no matter what temp :D
The reliable instant starting is something I'm glad to have back! It's starts beautifully and general response and smoothness with acceleration is noticeably better. I wish I could have gotten around to doing the injectors sooner, but I'm happy now in any case. The fumes are also gone.
The vacuum leak is still something I have to do, and unfortunately I may have to remove the inlet manifold which I'm certain is gonna be significantly more time consuming.
However, my next job with the 280 is to remove the old exhaust manifold "Y-piece" which has cracked (as they all do...) and replace it with a new W123 piece that I've bought. That way it will be a bit quieter :eek:
As for my 350SE...
Well for starters, it seemed the timing was moving around and I was getting inconsistent performance. As expected, the distributor had bad vertical movement in the shaft. Thankfully, I had a good distributor sitting in a 450SE (they seem to be interchangeable like many parts with the M116 and M117 motor) parts car which I swapped over to mine a month or so ago. Had to get the timing re-done as I struggled to do it myself, despite having a timing light I had trouble not only interpreting the marks on the crankshaft pulley, but seeing all the way down there in the first place...
That had a nice improvement also, in power. The only strange thing is, after installing the new distributor, the fast idle, which never originally worked on this car, started working again. But this time it never goes off even when warmed up! So my thoughts are that the Air Slide had "somehow" come unstuck when I changed distributors (no idea how though!) and then stuck in the opposite position (open) :eek:
Well, that's the theory. So I'm going to have to remove it and try to free it up. Basically, the car will always idle around 1500 or so even with the idle screw all the way down unless I remove the Air Temperature Sensor (T1) on the air cleaner snorkel, which brings the idle right down to a normal level. For the time being, I have the T1 connector disconnected. Hopefully that has little effect on performance.
So that's one little job to do.
I also suspect the MPS needs replacing, as performance around 20-60 km/h driving around town the performance is a little inconsistent and hesitant in response. Well basically there's no smooth transition between certain revs. Thanks to Oscar and his previous threads for helping to understand this ;)
I'll need to test the MPS first obviously, but I highly suspect it seeing as the symptoms fit perfectly.
The only other thing is, until I get the valve stem seals done, cylinder 3 and 6 tend to oil foul their respective spark plugs. The rest of the plugs are fine, but those two need cleaning every so often.
Other than those mechanical fixes/problems, I've done a little tidy up with the 350's appearance. So I've got some pics here to show. I don't have any of the 280SEL unfortunately, as it's locked up and covered in the garage at the moment and it's wheel trims are getting repainted currently at the bodyworks.
So here's my 350SE. It looks ALOT better than the neglected $800 car I originally purchased, in my opinion. Amazing what some TLC and a reasonably small amount of money (SS wheel arch trims, touch up paint etc) can do :cool:
Excuse dodgy camera phone lighting...
Excuse the dodgy Milan Brown paint making it's way into the photo..:rolleyes:
The 350 will, however, in time receive a full new paint job as the bonnet and a few other areas are cracked and well, not good. When that happens, the spoiler from Styria will be fitted and painted. :D
Don't want the lovely spoiler showing up the poor front of the car, the way it is currently ;)
FYI Styria, the second spoiler we have has been placed on the supposed track car, the manual 280SE, though it's not painted yet.
Nice update Andrew...
Well done..
Andrew280SEL
Andrew280SEL
Tasmania, Australia
Well I didn't get around to testing the MPS or TPS today on the 350SE as I was kind of hoping to do, but instead I cleaned the no.3 and no.6 spark plugs which as I said foul up with oil after a while (figured it was time since I noticed some slight 'missing' yesterday).
However what I also did today, for the first time, was analyze and try to adjust the throttle linkage if need be. As I recall Styria originally made a thread way back on the ORG detailing how it was worth checking as the throttle linkage can go a bit out of adjustment after all these years, which sprung to my mind so I thought I'd try and see what mine was like.
I got my dad to put the pedal flat to the floor, and low and behold, there was at least a good quarter of movement left before the intake flap was fully open :eek:
So I adjusted it until it would fully open, and the difference is really amazing! General response feels better and of course having actual full throttle attainable is nice :D
I'm gonna have to go around all the cars and check this out now.:)
Andrew280SEL My W123 230E (plus update on other Benzes etc) Mercedes W123 17
chrisp Wilhelm Update Mercedes W116 5
s class update on the W124 AMG 3.6 project Mercedes W124, W201, W140 and R129 10
G Original Becker, or update? Discuss. Interiors 27
oscar Povo update Motorsports 37
G Update on WASABI the Crayford wagon. Mercedes W116 32
oscar #3 Povo update Motorsports 62
CraigS Tatra update Talking Torque 33
B Free 280SEL in NSW Gumtree/eBay/Facebook Listings 1
Oversize 280SEL for sale on eBay Gumtree/eBay/Facebook Listings 5
260ebenz 280SEL for sale Mercedes W116 2
Styria Mercedes 280SEL - W116 Road Tests 6
Styria 1976 Mercedes 280SEL Road Tests 0
Oversize Very nice 280SEL for sale Gumtree/eBay/Facebook Listings 5
Oversize W116 280SEL for sale Gumtree/eBay/Facebook Listings 8
Oversize A low rider minitruck (280SEL)?? Gumtree/eBay/Facebook Listings 9
Oversize 280SEL on Ebay Gumtree/eBay/Facebook Listings 2
Oversize Green 280SEL for sale in Melbourne Gumtree/eBay/Facebook Listings 11
motec 6.9 280sel on ebay Gumtree/eBay/Facebook Listings 1
Oversize 280SEL for sale Gumtree/eBay/Facebook Listings 10
L 280SEL for sale by the Maitland Progress Association Gumtree/eBay/Facebook Listings 1
116Benz 280SE & 280SEL for sale Gumtree/eBay/Facebook Listings 9
SELfor50 36mins to go - 280SEL "BEST IN AUSTRALIA" Gumtree/eBay/Facebook Listings 4
abl567 W108 280SEL strip out Mercedes W108 and W109 4
B Becker Mexico Cassette - removed from 1979 280SEL Gumtree/eBay/Facebook Listings 12
B 79 280SEL in Melbourne's west on eBay Gumtree/eBay/Facebook Listings 0
zej 350SE finally registered and on the road again Mercedes W116 10
zej 1973 350SE Progress.... Mercedes W116 6
s class 350SE trans failure Mechanicals 11
motec 6.9 Time warp 350SE 70000km Gumtree/eBay/Facebook Listings 5
motec 6.9 Nice 350SE on eBay Gumtree/eBay/Facebook Listings 3
SELfor50 FS: 350SE W116 - On All classifieds Gumtree/eBay/Facebook Listings 0
450SE 280SE & 350SE for sale Gumtree/eBay/Facebook Listings 10
Michel Reasonnable 350SE in Queensland Gumtree/eBay/Facebook Listings 4
B For 107 fans 350SLC manual - pity its not a 350SE.. Gumtree/eBay/Facebook Listings 7
B WTB: Instrument cluster 350SE (or just the speedo) Gumtree/eBay/Facebook Listings 2
