Tidy up your 116
I am one of those fellows that likes to do things better than what one really has the time for. In this instance, the picture reveals a somewhat unfortunate mixture of the original taxi white, accumulated dirt that you don't ever see unless you start dismantling bodyparts and things just look, well, messy.
So out comes some spare MB877 Petrol and a paint brush to give us this.....
Of course, the front bar and the two covering panels for the electric washer motors for the wipers have been removed for repainting and refurbishment.
Regards Styria
That definitely looks nicer with that fresh coat of blue
Thanks Michel - it does look better. I have also, or hopefully did have, a couple of persistent oil leaks - one from the engine, and another from the gearbox. I had already fitted new rocker cover gaskets some while back and quite frankly I got the 'kaputts' when the leak persisted. So this time I decided to reseal (again) the rocker covers and I discovered that one stud had not been sitting properly (down far enough) for the retaining nut to be tightened down properly. That has now been rectified by the use of an Allen headed bolt and copper sealing washers on all studs. Hopefully, that will eliminate the oil leak from the engine.
As far as the box is concerned, some while ago I changed the filter and rubber seal, but a persistent oil leak seemed to emanate from the two pan retaining bolts from the rear of the box. I have now removed and refitted those with a slight smear of silastic sealant. Hopefully again, this will get rid of the oil leak from that area. Whilst at it, I decided to change the engine oil, and I am surprised that there is still a slight amount of sludge in the recess of the bolt that seals the bottom of the oil tank - this is despite the fact that I have regularly changed the oil since carrying out the valve grind and decoke some two years ago - yes two years. This just seems to re-affirm the amount of sludge that must have been internally in the engine prior to head removal. Regards Styria.
Styria Comprehensive 116 history Websites and Links 1
A 116 mud flaps Exteriors and Body Repairs 4
Styria 116 images on google Websites and Links 3
Styria 116 model - Minichamps Gumtree/eBay/Facebook Listings 5
Des W-116 estate Mercedes W116 18
mrkozzy 116 Online Service Manual Websites and Links 1
Styria Black 116 leather Gumtree/eBay/Facebook Listings 3
Styria 116 Flooring Interiors 6
L Cheap 116 Interior? Gumtree/eBay/Facebook Listings 2
M Swap 126 ortho bits into 116 seats? Interiors 0
Styria great 108/109 and 116 videos Websites and Links 1
Styria german website - 116 (and others) Websites and Links 1
WGB A couple of peculiar 116 rattles Mechanicals 3
Styria Chassis 116 colour chart - paint Articles 16
Styria Chassis 116 cars galore Gumtree/eBay/Facebook Listings 5
J 116 alloy wheels finish in 1 hour Gumtree/eBay/Facebook Listings 0
J 116 Leather Seats required Mercedes W116 4
Styria Timber for Dash - early 116 Gumtree/eBay/Facebook Listings 11
Styria Timber for Dash - early 116 Gumtree/eBay/Facebook Listings 0
E200K Not a 116, but..... Talking Torque 16
Styria Blinker relay - 116's and 107's Interiors 6
B 116 Performance upgrade. Is it possible? Talking Torque 8
Michel Headlight Covers... for 116 Gumtree/eBay/Facebook Listings 10
SELfor50 Team 116 #1 on Dyno Motorsports 8
Styria European 116's Mercedes W116 24
SELfor50 Team 116 #1 - Checklist for Sandown Motorsports 28
116Benz 116 Brochures Gumtree/eBay/Facebook Listings 2
B Team116#2 chronicle 25May08: Say hello to 116! Motorsports 11
R 116 grille trim Exteriors and Body Repairs 5
Des Nice looking 116 Mercedes W116 11
B Don't tell me the 116 and 126 use th same coil springs?! Gumtree/eBay/Facebook Listings 5
Michel Taillight Seals for 116 Exteriors and Body Repairs 9
