Exclusive High-Performance Coupe for the Discerning Motorist
Affalterbach ・Sensational appearance, unique performance data, with light-weight design throughout and total exclusivity - that's the new Mercedes-Benz SL 65 AMG Black Series. This high-performance coup・is a motorsport engineering thoroughbred, opening up new drive dynamic vistas to sports car enthusiasts. The AMG 6.0 litre V12 biturbo engine, with a maximum output of 493 kW/670 hp and 1000 Newtonmetres of torque, guarantees super sports car level performance. The powerful two-seater was developed in the AMG PERFORMANCE STUDIO and represents the continuation of the highly successful Black Series strategy pursued by AMG, the Mercedes-Benz Cars Performance brand.
Broad, muscular and ready to pounce - that's the new Mercedes-Benz SL 65 AMG Black Series. Even when stationary, the coup・ssuperlative dynamism can arouse great passions. The strikingly broad mudguards, the retractable rear spoiler and the rear apron with diffuser fins point unmistakably to its motorsport origins, part of the Mercedes-AMG corporate philosophy for more than 40 years. One glance at the new SL 65 AMG Black Series and you are reminded of the successful AMG racing sports cars like the present DTM C-Class or the 1997 CLK-GTR from the FIA-GT series.
Wide cooling air apertures in the front apron and the bonnet are the clearest indication of the massive power of this AMG twelve-cylinder, biturbocharged engine. From its 5980 cubic capacity, the AMG V12's engine generates a maximum power of 493 kW/670 hp at 5400 rpm and an electronically limited torque of 1000 Newtonmetres between 2200 and 4200 rpm. Without a limiter, the AMG 6.0 litre V12 biturbo engine, which is hand-built in the AMG engine factory in accordance with the "one man ・one engine" philosophy, would achieve a maximum torque of 1200 Newtonmetres. Compared with the basis power pack in the 450 kW/612 hp SL 65 AMG, new turbochargers were developed for the twelve-cylinder SL 65 AMG Black Series engine. The turbochargers' spiral cross-section, now twelve per cent larger, and the optimised wastegate ducts permit increased air throughput and an even more impressive display of power in all engine speed ranges. The modified intake air ducting results in an even more spontaneous response. The new design for the AMG sports exhaust gas system's rear silencers reduce the exhaust gas backpressure and help increase the power output. The acoustic side effect of this is to produce a distinctive twelve-cylinder sound, typically evocative of AMG engine tuning, from the two trapezoidal tail pipes. The low-temperature charge air cooler, now 30 per cent more powerful, and the optimised water cooling system guarantee not only that the power generated under extreme dynamic driving conditions is exploited to the maximum but also the greatest possible fatigue strength at high outside temperatures.
Unique performance thanks to attractive power-to-weight ratio
The extraordinary engine specifications, which make the SL 65 AMG Black Series the most powerful AMG model yet, help to produce unique performance data: from a standing start, it takes just 3.9 seconds to reach 100 km/h; top speed is 320 km/h (electronically limited).
Configuration and number of cylinders: V12
Valves per cylinder: 3
Cubic capacity: 5980 cm3
Bore x stroke: 82.6mm x 93.0mm
Compression ratio: 9.0: 1
Power output: 493kW/670hp @ 5400 rpm
Max. torque: 1000Nm at 2200-4200 rpm
Acceleration 0-100 km/h: 3.9 sec
Top speed: 320 km/h*
* electronically limited.
