Targa High Country 2019
And I nearly went last year!! Bugger I missed this racing 450SEL & maybe the opportunity to look under the hood... Sounds like a manual trans too!!
https://youtu.be/pTf8GUJNFfU
Under the hood... Hopefully better images to come later this week...
5.3, Carillo rods and pistons, heads tweaked, cams, multi throttle bodies, exhaust, elec water pump+++. T5 dog box with sequential shifter, Ve diff with Kaaz lsd
Cranks did machining, Speedworks did heads. Tighe cams...
I’m dropping by their shop on Friday...
Saw this car in person today & spoke with the lovely owner! Simply amazing work!! I can’t detail too much, as the guy is quite private...
Apparently 440hp!!! So based on similar achievable efficiency could we not assume a 560 could make 460hp & a 6.9 540hp? I intend to test the theory....
