I have removed the sunroof frame/panel from my W126 for refurbishment. I'll be doing this on both of my 116s shortly as well, and they may even be identical.
Between the sunroof frame and the roof of the car is a foam seal. They are not very expensive from the dealer, but I'm wondering is there an alternative to this? It may be that when this foam starts decaying, it promotes rust.
I also found that the rubber seal across the sliding roof panel at the rear is critical. When in good condition, it channels some water off to the side drains in the frame. If it is dry and cracked, it allows water to overflow directly into the tray, thus onto the headliner and down the C Pillars, pooling under the back seat, as was my case!
Fortunately, there is no rust in the frame, or the roof structure. Just old dry seals.
Here's the frame, prepared for the new frame-to-roof seal, whatever that may be...
By tim_w116, shot with DMC-FX01 at 2009-07-24
