G
gerodan
Hi, this is my first question because this is my first problem.
I've had my 450SE for about two months now and its first major problem is that it is killing batteries. It seems that the alternator is only charging the battery every so often.
Let me explain. It all started a week or so ago when I was sitting in the car waiting to meet someone. I was listening to the radio when it just died out altogether. I figured the battery had gone flat, but 10 minutes later when the person I was waiting for had arrived I tried starting it and it fired up fine. We drove across the city (only about 5km). We hopped out for 5 minutes but when we got back in it wouldn't start. The people we visited had jumped leads, so we started the car and drove around some more. I didn't stop the car in case it wouldn't start. The next morning it started fine. I drove to work and all that. Spent all day at work, then headed home. Again, it started fine. Halfway home it started running rough at idle. It was as though there was only spark on every second cylinder. I was stuck in traffic and found that if I put it in neutral while waiting at traffic lights then it would keep running, however this trick didn't work when I was in stop/start traffic on the ramp up to the Anzac Bridge. I couldn't get into neutral quickly enough so, with no spark, the engine stalled. I couldn't start it again.
So, hoping that the battery was just getting old, I replaced it with another one from another car which I knew to work fine as it was fairly new. It only took two days for this one to die in the Merc.
SO. What I know is that the battery is not being charged. I have experimented with the situation by starting the car with a charged battery and then disconnecting it in the hope of proving whether or not the alternator is faulty. Well. I'm not sure. See, when the battery is disconnected it runs rough but with enough throttle in neutral it will run with no battery. Obviously however the net charging output of the alternator is a negative figure because I've flattened two batteries in four days.
My question now is, where should I look at getting a new alternator from, or is there a likely problem/common fix which I may not be aware of.
All help appreciated.
Gerodan.
Gerodan.
