With the advent of the extremely hot weather some sections of Australia, including Sydney, have experienced, failure of water pumps, particularly 6.9's, have become an issue.
There has been confusion from time to time regarding the amount of work involved in order to remove the pump. Some have maintained that the crankshaft damper requires removal, others have suggested that it would be best to also remove the water pump housing that separates the pump from the engine block.
There is absolutely no doubt that it is NOT necessary to remove the damper. Whilst the impeller is ALMOST an interference fit in the housing, the pump can be removed.
Regarding the removal of the housing itself, I don't particularly like removing those on account of two reasons.
1) The lower flange bolt on the off side can be rusted in and it is quite easy to damage the Allen headed bolt, and
2)There is a spacing washer between the engine block and the Air Conditioning bracket. That spacer can be quite awkward to replace, but it has to be in place to stop coolant leakage from that particular retaining bolt. In addition, I prefer to see a hex bolt in its place. Regards Styria
