Pretty old, and frustrating subject, isn't it ? Well no, the subject is boring, the frustration comes with innumerable unsuccessful attempts to polish, cajole, do whatever, in an effort to bring back that shine, that lustre the stuff has been blessed with when new.
I have gone through my share of headscratching etc., and the last method I tried was to use the 3M stainless steel polish as advocated by BAR. Alas, again no real solution, nor satisfactory result. I had also not forgotten SEL69L's solution to wipe clear lacquer on the trim pieces and he felt that there was a definite improvement.
So, what have I done ? Well, I have just experimented with my secret formula. What do you think ?
What I had noticed many times that if one would wet the 'milky' trim pieces, they'd be all shiny whilst wet. Once dry, however, it would be back to the somewhat shabby appearance. Anyway, I decided to expand on SEL69L's idea and actually two pack clear the trim pieces after having cleaned them as best as possible with detergent, fine steel wool and prepsol. The result is there to see - I think the improvement is remarkable. It's impossible to remove scratch marks etc., but I would rater have 'shiny scratch marks" instead of milky ones.
Now, I take no responsibility for what may happen down the track. The clear may peel off, it may get dull, but I have generally found that 2 pack products last and stick well.
The next lot of photos of trim items in the boot of my gold 450 were sprayed in pressure pack clear gloss. Again, the shine is quite remarkable, but I suspect that it will not last as well. I used the same cleaning process, but heated the trim pieces prior to spraying.
So far, I have every reason to be extremely pleased with my effort. Remember, of course, that photos can lie to some extent, but it was worth a try. Regards Styria
