M116/M117 D-Jet injectors
More threads by mercdz
mercdz
South Western Victoria
It has been suggested on another forum that:
"The injectors are the same as those used a Datsun 24OZ . Same Bosch. D - Jet system under license then."
Is this correct?
c107 AC Compressors for the M116/M117 and 6.9 Mercedes W116 5
N M116 into 280S? Mechanicals 4
mathew M116 won't start Mercedes W126 58
mathew M116 Dutycycle checking Mercedes W126 4
smueller99au M116 3.5 Headbolts Mechanicals 5
smueller99au M116 3.5 Headbolts Mercedes R/C107 0
TJ 450 M116 Alloy Block Bore Condition Mercedes R/C107 9
c107 M117 450 - Worn Rocker Arms Mercedes W116 3
Oversize C111 Epic Soundtrack M117 TT Motorsports 6
Oversize Sbarro Twin Turbo M117 Talking Torque 0
Oversize M117 Burnout Websites and Links 3
motec 6.9 Gemballa w126sec m117 6.9 Talking Torque 2
Tony66_au M117 wont idle Mechanicals 4
SELfor50 M117 Piston Gumtree/eBay/Facebook Listings 0
Des M117 Tuning Motorsports 7
WGB M117 450 - 370bhp Motorsports 25
SELfor50 M117 Gearbox Gumtree/eBay/Facebook Listings 4
SELfor50 M117 Engine Gumtree/eBay/Facebook Listings 3
Styria Testing K-Jet Injectors Technical Information 23
Michel D-Jet, K-Jet, etc... Mercedes W116 8
Styria K-Jet Injector problems Mechanicals 14
