M116 into 280S?
More threads by Nab
Nab
Distinguished
Perth Australia
I've picked up an Australian delivered 350SEL, 293,000km and pretty rusty.
I'm keen to convert my 280S to V8 and this seems to be a perfect opportunity but I want to run a carby.
The D-jet is currently not operational and I believe I will go down a rabbit hole of effort and money getting it running right. Putting fuel directly into the manifold sees it running with great oil pressure and no smoke. Compression test is 160psi minimum on all cylinders so it's pointing to a sound motor.
I have a suitable carby from another project so the only thing stopping me is an inlet manifold to suit a carby. I've seen adapters on the standard manifold but they seem to really deplete any performance an economy. Custom manifolds seem the way to go but is beyond my fabrication skills.
Anyone know of any manifolds available?
I will be parting the car out, located Perth Western Australia.
Colour is 623H - Light Ivory but has been resprayed at some stage
Interior is 104 - Saffron MB Tex
N
Nab
Distinguished
Perth Australia
Today I replaced the fuel filter with a cheapy, replaced a couple of fuel lines, put in $20 of PULP and it fired up!!! Idles and revs but a bit rough as expected.
N
Nab
Distinguished
Perth Australia
I've had no luck with manifolds etc so I'm not going to do the transplant. I'm wrecking this car now, anyone interested in the 3.5 motor and wants to see it running before I take parts off that will stop it running?
Let me know if you need anything.
mathew M116 won't start Mercedes W126 58
mathew M116 Dutycycle checking Mercedes W126 4
smueller99au M116 3.5 Headbolts Mechanicals 5
smueller99au M116 3.5 Headbolts Mercedes R/C107 0
TJ 450 M116 Alloy Block Bore Condition Mercedes R/C107 9
N Converting 280S auto to manual? Mechanicals 8
braminator123 280S - white over green - 140000km Gumtree/eBay/Facebook Listings 3
6.9forever 280S with 8000 miles. Never seen anything like it (since 1975!) Mercedes W116 14
260ebenz $39,410 US 280S Mercedes? Gumtree/eBay/Facebook Listings 2
mrkozzy e-bay 280s parts car in Adelaide Gumtree/eBay/Facebook Listings 4
sergeich77 280s papyrus white Mercedes W116 6
motec 6.9 280s turbo Gumtree/eBay/Facebook Listings 3
motorpsycho Clutch or slave cylinder problems with Malaysian build 280S Mechanicals 7
B Povo's manky sister: 280S/M ADL Motorsports 4
Des Perhaps I should do this with my 280S? Talking Torque 0
L 280S - One Owner! Gumtree/eBay/Facebook Listings 9
B Imagine this motor in a TeamW116 280S ? Gumtree/eBay/Facebook Listings 5
Michel Mercedes 280s 1976 $1500 reserve (4spd manual) Gumtree/eBay/Facebook Listings 0
B Black interior: 280S/SE in Victoria, Au Gumtree/eBay/Facebook Listings 0
