Last rites for a fuel pump
More threads by John S
This was on the USA forum "mercedes-bounces@mercedeslist.com", and it seems worth passing on to 116 & 107 enthusiasts as a last resort for reviving a fuel pump.
You might try a trick that George Murphy once offered. Remove the pump from the car and attach a piece of hose to the pump outlet. Stick the free end of the hose into a can of diesel fuel and hook the pump up with reverse polarity so it runs backwards. Aim the inlet port into an appropriate container. This can help as sometimes the pump gets a bit jammed up with particulate matter and back flushing can occasionally clear things up. Be sure to use diesel instead of gasoline due to the inherent fire hazard especially if your electrical connections arc and spark a bit.
Oversize The last few weeks of 5398 Mercedes W116 15
S Hybrid which last Talking Torque 12
c107 1990 560SEC - The last panzerwagon Mercedes W126 9
S last word Articles 0
CraigS Last weekend's wrenching Talking Torque 6
motec 6.9 The last Horch Talking Torque 1
6.9forever A-Class launch last night Talking Torque 23
WGB Last pieces of rubber between bum and road Exteriors and Body Repairs 16
motec 6.9 6.9 on ebay sold shannons last year Gumtree/eBay/Facebook Listings 6
450SE It's back!!! (at last) Exteriors and Body Repairs 27
c107 Old Fuel Mechanicals 24
A fuel tank Mechanicals 3
