[JT] The 1952/53 Rover P4 Models
At the Rover P4 National in mid-May, I wasn’t the only one struck by the low numbers of 1952 and 1953 models in attendance. It’s a shame that these models don’t get more enthusiast attention, because they incorporated huge strides in the development of the P4 range. So I thought I’d remind myself of what those huge strides were.
Please do “like” this post if you’ve found it worthwhile, if only to help me judge how popular one subject is against another. And, as always, if you want to share it or copy it, please feel free to do so; I know you’ll acknowledge where you found it. (James Taylor's Facebook Feed - https://www.facebook.com/james.t.roverphile)
(At this point, I'll reassure anybody who was following the story of the TDV6 diesel engines that I'll resume their story with the 3-litre types next time.)
GETTING IT RIGHT
Far more work went into the 1952-model Rover 75 than met the eye when the cars were announced. In typical Rover fashion, all the new season’s changes looked like evolution when in fact they were the results of a comprehensive redesign. The development engineer in charge of the whole thing was Chris Goode, who had taken over leadership of the P4 project from “Bro” Ward.
All the public saw at first glance was a new front end with a reassuringly Rover-like grille. It was certainly more attractive than the rather odd front end of the earlier Cyclops models, which had prompted some rumblings of discontent from Rover’s traditional customers. However, that was far from being the point of the exercise. In fact, there were two very practical reasons why Rover had redesigned the front end.
On the one hand, the original horizontally slatted grille with its central foglamp restricted airflow to the radiator and contributed to overheating in some circumstances. On the other, the twin air intakes mounted below the headlamps picked up not only the air they were designed to feed to the heating and ventilating system but also exhaust fumes when the early cars were standing in traffic.
The new Rover front end was a brilliant but simple piece of design. In place of the body-colour grille came an elegant new one with a bright metal frame and narrow anodised slats arranged horizontally. With the addition of the traditional triangular Rover badge at the top of a bright central spine, it not only harked back to the respected earlier designs but also let through the necessary amounts of cooling air.
The basic shape of the wings remained unchanged, but the headlamps were recessed directly and neatly into the wing fronts. The twin intakes below the headlamps meanwhile disappeared as the whole heating and cooling system was revised. The design solution was again simple – and so simple that you can’t help wondering why the complex original type was designed in the first place. A hinged flap was placed at the base of the windscreen, cutting into the back of the bonnet, and ideally placed to take in air at a level high enough to avoid exhaust fumes. It could be closed manually by a lever inside the car to prevent an excess of cold air getting into the cabin, and for good measure, a larger heater provided an increased output of 3½ kilowatts.
The only casualty of this front end redesign was that there was no longer a fog lamp as standard. Rover nevertheless compensated by offering one as an optional extra. It bolted to the front bumper valance and, later, would become part of the standard specification of the new top-model 90.
It’s perhaps surprising that we know so little about the creation of this new front end. There can be no doubt that the driving force behind it was Rover’s Chief Engineer, Maurice Wilks. He would certainly have been helped by Ben Loker, the Chief Body Designer. But where did the inspiration for that grille come from? Back in 1951 when it must have been designed, there were not many obvious precedents. American grilles tended to be horizontal, and European ones to be vertical. The exceptions were from some of the bespoke coachbuilders, primarily in France and in Italy.
The Rover photographic archives contain no clues except that the new front end was first photographed on 18 June 1951. The pictures were taken by Rover’s regular contract photographer, John Toft-Bate, who then took a further set on 22 August. Both sets were listed as showing the 1952 models, but in practice the revised cars did not enter production until January, and would not be introduced on the world stage until the Geneva Show in March. For this, Rover prepared a special display chassis.
The engine and gearbox of the 1952 chassis were essentially unchanged. The 75 still had its 2103cc six-cylinder IOE engine with twin SU carburettors, and the gearbox was still a four-speed with synchromesh only on third and top, a column-mounted change lever, and a freewheel. A new exhaust heat shield made a welcome reduction to the heat transmitted to the interior of the car, but the major improvement to the 1952 models’ refinement came from new composite rubber and steel mountings between body and chassis that reduced the transmission of road noise into the body shell. Spen King once told me that these completely transformed the P4, in his opinion.
Silentbloc mountings that used the same principle were also fitted to the front suspension, where rubber between springs and suspension arms stopped road noise being transmitted up the springs. Meanwhile, the rear chassis cross-member was now slightly dished to accommodate a wedge-shaped fuel tank. This whole area had been redesigned to provide better accommodation for the spare wheel, which now sat under the boot floor. The wheel was accessible through its own hinged door which could be locked shut by a pin operated from inside the boot.
The boot also had a spring-balanced lid now, instead of the temperamental self-locking prop on the earlier cars, and a neater handle than before. Without the spare wheel, its floor was unobstructed, although it still sloped towards the rear. The right-hand rear corner of the boot became the new (and permanent) home for the electric fuel pump, where it suffered from neither vapour locks (as on the 1950 cars) nor water damage (as on the 1951 models).
Invisibly, the body now sat an inch higher than before at the rear, giving extra passenger headroom. A wider rear window made for a lighter cabin, and better seat comfort came from a spring base underneath the cushions. A recessed backrest for the front bench added knee room for rear passengers, while alterations lower down improved foot room. The driver would have noticed a full circular horn ring instead of the half-ring of the earlier cars, while an organ-type accelerator pedal allowed more sensitive throttle control. New rotary switches replaced the earlier push-pull type and, instead of a low-fuel warning light, a switch gave access to a reserve supply of petrol (made possible by rearranged fuel lines).
Amid all this change, Rover chose not to offer any new paint or interior trim colours for 1952. So that season’s models had the same five paint options and the same five leather options as before. Perhaps this was for manufacturing convenience, or perhaps it provided the sort of reassuring continuity that Rover customers seem to have liked. One further small change involving the paint was made, though: the rear light plinths, originally chromed, were now painted in the body colour.
The 1953 models
The positive reception that greeted the 1952 models made clear that Rover did not need to make any major changes. The ones they did make were to the paint colour options. The Black, Ivory and Pastel Blue favourites were retained, but in place of the two greens came Sage Green and Light Grey. As for interior colours, the previous year’s five options remained unchanged.
The basic five-colour paint range was also extended by extra-cost two-tone options, in which the roof was painted a darker colour than the lower body. The options featured the two new colours, but in each case with a second colour that was not available on its own. There was thus Dark Grey for the roof of Light Grey cars, while Light Green was used for the lower panels of cars with a Sage Green roof. Both combinations were most attractive, although the two-tone grey seems to have been more popular. Interestingly, several 1952 models had served as two-tone prototypes in the first half of the year, and rejected options included Green with Grey, and two-tone Blue; Very Dark Red with Red is also recorded, although this may have been an experimental single-tone paint with a Red interior.
With a single exception, only detail changes were made to the cars during the 1953 season. The exception occurred quite early on, after just 1238 cars had been made, and was the deletion of the Panhard rod on the rear axle. This had given some trouble on the earlier cars, and Rover had now concluded that it was unnecessary. They now suggested that dealers should remove it from older models when they came in for service, so few cars that survive still have it.
Progress quantified
As the 1952 season was just eight months long and the 1951 season lasted 16 months, the actual production totals for these years can be misleading. However, combining the totals of 10,279 for 1951 and 5768 for 1952 gives a figure of 16,047, and averaged out that gives just over 8023 cars a year. That shows how much improvement had been made on the 1950-season figure of 5250.
For the 1953 season, Rover probably deliberately capped production at 8000 cars, leaving the major increase in the P4’s popularity to come in the 1954 season when there were three models available rather than just one. And that year, the production total would increase massively to 13,486, or more than 250% of the first year’s production total. Alongside the huge increases in demand for Land Rovers, that made clear just how well Rover were now doing.
First picture: Lakeside Green was still available for 1952, although this promotional postcard almost certainly used a hand-coloured black and white picture. LUE 950 was a RHD Export model, number 2436-0035.
Second picture: This rear view of a late 1953 car shows the redesigned boot lid handle, the wider rear window, and the body-colour light plinths. The reflectors would have been added circa 1954 to meet new UK regulations.
(More pictures in the Comments below.)
Perhaps this car on the 1952 sales brochure was supposed to be Pastel Blue. If so, it was a very poor representation of the colour!
This overhead view of a press demonstrator shows the new front end with the air vent in the open position.
The interior changes were minor, and would not have frightened existing Rover customers. This picture was supposedly taken on the Rover stand at Geneva in 1952.
Putting the spare wheel into its own compartment gave a much more useable boot.
Was this real or was it posed? Either way, this picture from The Observer newspaper shows a gent apparently astounded by the front suspension of the 75. The picture is dated October 1952, and the show chassis was probably the one first seen earlier in the year.
This 1952 75 (NMP) was delivered to King Hussein of Jordan, who was crowned that year. The Jordanians were major buyers of Land Rovers and the car was probably specially finished as a gift – perhaps reflecting the colour on the 1952 sales brochure! It survives in the Royal Automobile Museum in Amman. And that's all for now, folks...
Should also note that if this James Taylor article has you interested in a P4, there are always a few nice ones for sale here:
There can't be too many classics that give you so much car for such a small outlay as the Rover P4.
260ebenz 1952 300 Adenauer Gumtree/eBay/Facebook Listings 1
motec 6.9 1952 300S Coupe Mercedes W186, W188, W189 and W100 9
Styria 1952 Mercedes 300SL Mercedes W198, W121 SL and W113 1
Styria The Rover P5/P5B Rover P4, P5 And P6 220
c107 Colour options for the R/C107 models Mercedes R/C107 1
c107 The W114/W115 models Mercedes W114 and W115 0
BenzBoy Tech data for later models Talking Torque 3
Styria '60s models - 250S/SE 300SE Coupe Mercedes W108 and W109 1
Styria 1978 W116 -All models Performance Data Road Tests 0
WGB 6.9 wiring diagram - Early and Late Models Technical Information 1
WGB 6.9 wiring diagram - Early and Late Models Technical Information 2
