450SE
I've got some sort of issue which appeared Friday night on the 450SE.
For some reason the motor cuts out for a split second while cruising along, giving a surge sensation when cutting back in. At idle (in Drive - say at a set of traffic lights) the miss hits at the wrong time & the engine dies a quick death. It restarts easily enough, but as the motor died on me half way into a major roundabout yesterday eek, I figured it's best to let the car rest!
The miss occurs when the engine is stone cold & also at temperature.
One incidental thing that I noticed the first time it happened is that the rev counter flew into the red zone momentarily when the miss occured although the revs did not increase. (I thought at the time that I was just imagining what I'd seen & the miss was a result of not paying attention to my foot).
I've tried driving with the air conditioner, fan & radio off thinking it could be a problem of lack of power. No difference.
The car has just had a brand new battery fitted.
It is also *slightly* slower to start up initially at the moment (say one extra crank of the engine).
All the leads to the distributor & plugs are firmly in place.
I went to my mechanic Saturday morning who took a quick look at it & short of adjusting the idle speed up a tad, said that I'd need to come back Monday as he was flat out. The idle adjustment didn't fix the problem... It will go into the shop tomorrow with hopefully an easy, minor repair... whatever it is...
Has anybody experienced this before or does anybody have any suggestions as to what it may possibly be?
