This is a common problem on 116 models - when the sliders become inoperative, it means that either of the two flaps has gone into the 'overcentre' position and become stuck. This invariably means that the foam that's glued to the flaps has disintegrated. It is in fact the foam that prevents the flaps from going overcentre. The first picture illustrates the flap and the poor state of the foam,
The two flaps are located within the bottom of the main heater box as shown.
The next two photos should show the position of the two flaps being attached to the appropriate levers operated by the slider controls - from the outside.
I need to apologize for the way I took the two previous pictures - whilst clear and all that, they don't quite illustrate the position of the flaps inside the bottom of the heater box. Try your best - in any case, if one ever gets down that far, they'll be able to visualize the flap arrangement quite easily.
If you haven't done this job previously, I would advise that you take photos to assist in the re-assembly of all components. I've done it previously, and I still take photos - it's too difficult otherwise as there are a lot of components that require removal before you can actually remove the separate bottom section that is attached to the main heater box. The first picture is an 'overall' view of dismantling procedures involved.
If you have a careful look at this second photograph, you will spot that particular lever just about in the very centre of the photograph. It portrudes through an opening in the main frame. That's a major cause of making this job so difficult and time consuming.
The next picture illustrates the very bottom section that is attached to the main unit, but needs to be removed before access gain be gained to the flaps.
Please take note of the lever located in the centre of this bottom box section - now, that lever will cause you all manner of grief because of its location in relation to the main frame that secures all your sliding controls and various other components. That lever sticks out far enough to prevent you from sliding this box sideways and out of the way so that you can remove the flaps. Why MB did not come up with a lever arrangement in "two" parts, I will never know. Furthermore, that main frame - it's in the way of everything and you've just got to keep dismantling until it can be pulled towards the back of the car to enable that lever to clear it when moving the box sideways. I don't mean to be negative, but honestly, this job will drive you to distraction. If it wasn't for that lever.........apart from a few other items, but one can cope with those with patience and perserverance. Regards Styria
N.B. There is more reading material in this old thread.
http://www.topklasse.org/forums/showthread.php?t=904
