Heater control panel in the console - how do I remove it?
More threads by B13
Hi guys,
Ok so I want to remove the heater control panel in my 450SE and replace it with one which only has a single Fan switch...
I've removed so far the ash tray and ash-tray bracket
The heater levers
The radio (which wasn't even mounted)
The A/C and Fan switches on the heater control panel
But I can't see how to remove the panel.
Any suggestions or pictures greatly appreciated.
Ian.
Hi B13, you have removed the four black plastic control levers, right? Okay, next prise out the two plastic 'up and down' bezels and once they are removed, you will see two self tappers that secure the bottom of the switch panel.
Once you have removed the self tappers, the whole lot will come out. Regards Styria
Mercules
Spiltting lanes
The panel has two little hooks at the top - after you take out the two screws behing the lever facia, you need to swing the bottom of it out first then it comes out :)
You have taken off the heater and fan rotary knobs but have you removed the two large nuts that hold the rotary controls to the front panel?
I don't think it will swing up until the two large nuts are undone.
S SL heater Matrix Interiors 0
S heater decides not to switch off Mercedes R/C107 2
S heater blower Mechanicals 0
Styria Heater slides inoperative Technical Information 18
B Heater Flap Stuck Interiors 6
B Heater hose part number..... Mercedes W116 1
c107 Rebuilding 6.9 level control valves Mercedes W116 1
Styria In-Depth guide to 6.9 emission control Articles 6
A Cruise control Mechanicals 4
S Cruise Control Recommended Suppliers 0
S 280 SL cruise control Mercedes R/C107 3
BenzBoy Cruise control in wet weather? Mechanicals 13
WGB Installing a LHD Climate control fan in a RHD HVAC car Mechanicals 1
B Fitting aftermarket cruise control? Mechanicals 6
B 6.9 upper control arms Mechanicals 14
Michel Cruise Control Mechanicals 36
WGB Vacuum Lines to Cruise Control Modulator Mechanicals 5
G Alternative Cruise Control Mechanism Mechanicals 1
Oversize There's a hole in that panel Talking Torque 9
Styria Switch panel Interiors 2
D Minor rust repair / panel beater Melb? Exteriors and Body Repairs 5
SELfor50 FS: Console Wood (Shifter Console, A/C Panel & Gear Lever) Gumtree/eBay/Facebook Listings 0
J Removing dents without panel beating Exteriors and Body Repairs 9
