hardtop SL W107
More threads by Terqel
Terqel
MELBOURNE
Hi all,
I don't know how to remove the side twist style locking pins on either side of the hardtop. They secure the hardtop to the body. I need to remove the RHS one to free the trim to get to the defrost wiring. If any body can help I would be most grateful.
regards
Hi Terqel, sorry I can't advise you specifically as we have not done a lot of work that you refer to. However, you may wish to investigate thoroughly the information provided by JohnS last September or October regarding this particular 107 site. It is excellent.
http://northernresource.com/mercedes/107-soft-top.htm
Regards Styria (wish you were in Sydney - would then be able to help you).
First of all, the hard top is probably stiff and stuck (if it hasn't been removed for a while).
In that case, I can assure you that you won't get it off all by yourself, you'll need two people (at least).
Have you released all latches? Including the safety one (in the middle)?
Are all levers in the right release position?
Is the safety release pulling back far enough?
You might need a bit of help by having two people lift and gently rock the top while you work the screw driver on the safety catch.
Good luck
T
Terqel
MELBOURNE
Hello Styria and Michel and thanks for your interest. Michel I am able to take the Hardtop off and on with no problems fits well and looks good sorry to mislead you. I want to remove the screw pins from the body of the Hardtop so I can in turn remove the trim to access the rear window defrost wiring. I think there must be a clip under the internal chrome head.
regards
motec 6.9 Will never buy a W107 Mercedes R/C107 20
Oversize New W107 FB Page Websites and Links 1
260ebenz Something for W107 fans Mercedes R/C107 6
6.9forever R/C107 not W107 Mercedes R/C107 3
Styria Tribute to our W107 Websites and Links 0
WiSeGuYY UTE from w107 slc Exteriors and Body Repairs 13
Oversize The best W107 video??? Motorsports 12
garrye w107 custom exhaust Mercedes R/C107 18
motec 6.9 W107 Mercedes R/C107 3
motec 6.9 w107 with m120 Mercedes R/C107 1
motec 6.9 w107 big block Mercedes R/C107 0
Oversize W116 & W107 pics on Youtube Websites and Links 2
garrye W107 SLC Side skirts Mercedes R/C107 14
Eagle Bill W107 Flasher canister Mercedes R/C107 2
S w116 parts on a w107 Mercedes R/C107 3
C Which W107 model? Mercedes R/C107 14
T 280SL W107 flasher can location Mercedes R/C107 7
B Wtb: W107 sl parts Mercedes R/C107 0
J W107 Repairs etc link. Mercedes R/C107 0
smueller99au W107 350SLC engine mounts Mechanicals 14
J W107 Subframe Recall Mercedes R/C107 3
J Keyless Entry for W107! Mercedes R/C107 3
Des The daddy of all W107's Mercedes R/C107 33
