At long last, I am close or have reached, the home stretch in the restoration of my 6.9. Sincere thanks must be extended to both Michel for helping out transport wise beyond the call of ANY duty, and to Jerry for carrying out such an excellent 2K - resparay job in two tone - something I have advocated for a long time and something I have finally been able to execute.
Much of the exterior work, and details thereof, are detailed in another section of the forum - I think it's in the Technical library. I may yet list part of that exterior work in numerical order in another thread, but for the time being I will concentrate on the interior work carried out.
1. Freshen up all four door step panels, replace and paint left front
passenger door trim.
2. Paint interior floors with POR 15 on RH side - front and rear.
3. Freshen up interior front, rear and side roof panels.
4. Freshen up door aperture draught strips - the CORRECT fitment of those
is quite difficult and time consuming.
You have a similar set-up in the other areas as well. I also find that the fitting of the interior side panel, the front and the 'A' pillar trim require considerable skill and patience - believe me.
5. Re-pack the back rest of the rear seat - it suffered from the normal
problem of the callicoe disintegrating and the stitching no longer holds
the pleats in place.
6. The bottom section was done years ago - still in great shape and had
several applications of saddle soap and hide food.
7. Freshen up sun visors.
8. New rear parcel shelf carpet.
9. Sunroof frame removed, cleaned of surface rust, and painted with
POR 15.
10.Service Pioneer Header unit at a cost of $100.00 - sorry, will need to
find picture.
11.Re-furbish and re-lacquer all interior timber panels - incidentally, I have
a good selection of those for sale. Not cheap, the amount of work is never
ending. Each panel has at least six or seven coats of clear.
12.Replacement Front and Rear screens.
13.Tint all windows.
14.New sill panel carpets, and carpets under front of back seat.
I think that just about covers the interior. It doesn't sound like much, but in reality the car has undergone a complete rebuilding process. Regards Styria
N.B. Well, I mustn't forget the centre console - completely re-done and freshened up.
Also, if you care to have a look at the top of the rear door, the fit of those strips where they join leaves a lot to be desired. This will need to be fixed as the photograph is somewhat unkind.
POR 15.
find picture.
