Fuel distributor & WUR rebuilding
More threads by CraigS
CraigS
I may require the above rebuilt and have tracked down a company in Sydney that does this, They are called Bower Power and the owners name is Peter Bower. He is located in Forest Hill. Cost is not cheap at $655 and $295 respectively, but cheaper than new ones. He prefers to match the components to each other. He also rebuilds injection pumps, including the 6.3, and appears quite familiar with them.
Can't recommend him at this stage as I have not used him, but just passing along the information if any one needs it in the future.
Hi Craig, the man is a well known Sydney fuel expert, but I have walked away from him once. Mind you, that was some three to four years ago, so things may have changed since then. It related to a 6.3 injection pump. I think that the suburb would be Forestville, on the North Shore. Regards Styria
2 guys on the 2008 rally had work done by them prior to the rally, both had their 6.3 injection pumps overfilling the governor by the end of the rally, could be coincedental, I didn't go into detail with them about what work was done so will not comment further
c107 Old Fuel Mechanicals 24
A fuel tank Mechanicals 3
