BenzLover
Benz Whisperer
Its done!
I was not able to get all of the pictures that I wanted,being alone to do this, and its pretty cold up here and snowing too.But I did install an insert (HeliCoil) on the oil filter housing.Not much room to drill from above so I had to go under the car and drill the hole to remove the old threading.I was lucky enough that I didn't have to buy a new HeliCoil kit since it was the same size and diameter as the one I did on my transmission oil pan last summer.http://benzguy.piczo.com/howtodothreadrepairsonTransmusinghelicoil?cr=7&linkvar=000044 In any case its a done deal,of course RED locktite was applied.Took less then an hour to complete the job but I had to wait about two hours before starting the engine,only to let the locktite set.
http://benzguy.piczo.com/wouldyouliketolearnfrommymistakes?cr=7
Cheers!
Cheers!
