Electiric seat switch
More threads by 260ebenz
Any advice would be appreciated in regards to my query.
Headrest retracts up and down just fine.
Drivers seat goes back and forth okay.
Just the drivers back rest does not retract.
So how can this be fixed?
Thought a pic of the switch might help?
Thank you.
Tim it is likely the switch not making proper contact. You could try spraying some electrical contact cleaner in behind the backrest button using the thin tube that comes with the can. You can get it at supercheap, it's really handy to have on hand
Re: Electric seat switch
Thanks Ant I will purchase a can of the electrical contact cleaner.
Directly spray the cleaner in behind the switch do not have to remove the trim insert?
I have never seen the stuff attack plastics Tim, but that doesn't mean you shouldn't test it first, a small spray on a rag wiped on some trim plastic that is out of site should confirm suitability.
The best way is to remove the switches completely, but if you can get it working without why not
Thank you Ant little project for me look forward to it.
Report back with an outcome which I have no doubt will be a good one!
:D
Good news seat switch fixed thanks to the electrical cleaner.
Did not even need to remove the insert three squirts of the cleaner in behind the switch hey presto fixed!
A beautiful day here at home so I washed 300SE and the Yaris today after two weeks both cars look superb!
The bill is on the way Tim, I accept all major cards:D
It was the 126 door I was swinging from Styria, in the manner one swings from the chandeliers with a Sabre in hand, maidens at the ready:D
.....was you upside down ? Were the maidens screeching with delight ?:D Regards Styria
....very educational and informative post on my part - if I may say so myself !
A Gentleman never tells Styria.
Eh, come on Anthony - from one gentleman to another gentleman, surely ! Anyway Anthony, you were dead right - I checked my non-Australian complied 420SEL and sure enough, the electric windows are operational without ignition on, nor engine running. Honestly, I am quite flabbergasted. Regards Styria
J Drivers seat stuck at full height adjustment. Mercedes W116 3
S seat belt holders Mercedes R/C107 4
S seat repair Mercedes R/C107 5
260ebenz Silicone spray seat belts Interiors 13
Oversize Seat upgrade Interiors 2
BenzBoy Advice on how to clean a light coloured seat belt? Interiors 25
WGB Another take on sagging seat bases Interiors 7
Martin280s Seat bases Interiors 6
BenzLover Re assembling the electric seat switch! Mechanicals 4
WGB New rear leather electric rear seat finally sorted. Interiors 6
WGB Delayed but welcome arrival of new rear seat leather Interiors 5
J Repair a broken seat spring Interiors 8
Michel Hazard Warning Switch Gumtree/eBay/Facebook Listings 2
S heater decides not to switch off Mercedes R/C107 2
300SDude Dead Window Switch Interiors 4
Styria Switch panel Interiors 2
