EFI -Electronic Fuel Ignition
More threads by WiSeGuYY
Hi Tarek I have used MSD in the past they are one of the best if not the best in ignition systems. Geoff only matched by ICE system's made in Australia
WiSeGuYY
WiSeGuYY
Cairo Egypt
HI MOTEC , can you elaborate a bit i'm not familier with this EFI thing but i donno the ICE one so please need a link too.
BEST REGARDS
TAREK
Geoff, I am not quite up to speed as to what functions the ICE system replaces/supplements when compared with the standard system. Is it just electronic/igniton systems it supplants, or are fuel systems affected as well. Not sure if you can elaborate further. Regards Styria
Hi Styria like MSD systems ICE make ingnition systems, distributors and coils systems or CDI Capacitive Discharge Ignitions . These type of ignitions are needed with high boost or compression engines as there spark is a lot stronger http://www.pavtek.com.au/index.php?option=com_content&task=view&id=123&Itemid=33 The Engine Masters Challenge in the USA the winners for the last 4 years have all had ICE systems fitted . Geoff :D
Hi Tarek just for you. I got around to posting the link. Geoff
S KJET EFI conversion - 280sl Mercedes R/C107 4
motec 6.9 EFI M-100 manifold Gumtree/eBay/Facebook Listings 11
SELfor50 Video Diary of 6.9 EFI/Blower Project - MUST SEE Mercedes W116 9
S Electronic Ignition Articles 2
S Electronic Injectors Articles 3
J Electronic Parts catalogue on line. Mechanicals 4
c107 Old Fuel Mechanicals 24
A fuel tank Mechanicals 3
