Hi guys after to long and to much money my 6.9 is now running David at TRG has emailed me dyno results which with some help i may be able to post after spending close to $4000 on exhaust and custom extractors $3200 on motec m48pro computer and $7000 on fuel rails, injectors ,fuel regulators, distributor pick up and crank angle sensors plus other bits and pieces i mutst say i am a little bit disapointed with the results last time it was on a dyno my 6.9 made 164kw at the rear wheels with a burnt exhaust valve and down on compression on 2 cylinders this time with a healthy motor with good compression it made wait for it 218.9 hp at the rear wheels or 163.5 kw at the rear wheels but the interesting thing is that it flat lined and made that power over 1300rpm that was with the standard 75mm throttle body which i have been told is the reason for the flat power curve but i was keen to have it running after 5 long years so we will see what happens when i get to modify the intake and put larger throttle body on motor as i believe that is where the restriction is looking forward to picking it up at the begining of next week as i am home this weekend and taking to paint shop before i fly out for work again at the end of next week
