The story starts before Christmas last year, this may be a bit long winded.
#2723 had a slight whine from the driveline under power from the day 1, after about 18 months and a full throttle blast across an intersection this developed into a rumble under power and I could no longer start the car in park, only reverse. everything pointed to broken down engine, subframe and trans mounts allowing the engine and trans to move around when driven.
I replaced the abovementioned rubber bits (at the right price from Tom Hanson at the Classic centre) drove down the street enjoying the tight new feel from the front end, heard a thump from underneath then a vibration.
I drained the sump and the first thing out was a piece of pinion tooth end of the road for that one
I explored every option available to me and purchased a reconditioned rear axle from a firm in VIC.
Someone we all know well installed it for me, worked beyond and above the call of duty and did a great job.
120 odd miles of driving, it felt like a new car! and bang again, this time the rear locked up through a mini roundabout and shuddered to a halt
I managed to limp home 100m or so, drained out $300 worth of MB LSD diff oil and along with the small gear bits in the oil found this peeking through the drain hole
I believe it to be a bevel gear from the diff spider that has dropped off.
I have a warranty on the reco diff and have contacted the vendor with positive reactions so far, here is hoping it all remains positive.
