Colour change question
More threads by GreaseMonkey
G
GreaseMonkey
I am thinking about rerpainting the Crayford wagon in either Pine Green or Cypress Green rather than the original Silver Green.
Part of the reason is that I think the brightwork on the W116s sets off the lines well and this contrast shows better on the darker colours.
Obviously if I go this route, I will have to do under the bonnet and all the hidden parts too and my question is;
in various Mercs I have had or seen, particularly the metallic ones, seem to have the interior parts painted the same colour but not as shiny. Is this because they paint the base colour, but do not bother with the clear top coat?
Just wondered if anyone knows, as I will try to get as close as I can to a factory job.
Thanks chaps.
Chris M.
OzBenzHead
Byron Shire NSW Australia
Chris: I've observed the exact same phenomenon in non-metallic non-clearcoat Benz engine bays. I have always assumed it's because those surfaces aren't cut, polished, or finished as the exterior is.
G
GreaseMonkey
My thougts exactly.
I may go the same route.
C.M.
If you paint something in basecoat and not finish it with a clear, the paint will deteriorate over time.
They probably use a 'matting' agent with the clear so as not to show too much shine in the engine bay.
That's what I was thinking Michel. Its disconcerting news nonetheless, as if one is intending a highly accurate restoration, its yet another point to deliberate over.
My red car is highly original and well cared for, and the engine bay paint is really quite matt.
It is common practice with modifed cars that are painted matt colours (flat black is one) to be done as I explained with varying degrees of matting agents.
It's funny, but I was discussing this today with the training manager of PPG in Australia at the SummerNats (huge car show for modified vehicles).
PPG will be releasing a matt (or satin) clear in the next few months
I have used Standox' matting agent with great success, though it is expensive. When I paint the 280's engine bay, it will be full high gloss in the interests of durability - its a daily driver, not a concours contender. Trusty rusty on the other had, now you got me thinking.
Michel's explanation is the most correct of all. We have noticed on many occasions that Mercedes will use the same exterior colour paint to all areas inside as well, the quality and quantity is certainly open to debate.
Engine Bay wise, I admit to not having noticed the difference between shiny (as in clear top coat) and a matt finish. As Michel says, without the protection of a proper top coat, the paint would deteriorate. If I were to paint an engine bay, a clear top coat would be a MUST. Regards Styria
G
GreaseMonkey
So, it gets interesting.
Is there, or is there not a matting agent used?
And if so, why?
I have noticed this before on my other cars, all internal surfaces are not glossy, under carpets etc.
So, asssuming the cars are maybe painted inside and out with the basecoat, why would M-B use a non-glossy topcoat on some parts when we would assume it would be easier to use the same all over if required?
The paint on my older 280E - Petrol metallic - started to burn off, the bootlid was worse, but the roof and bonnet have started to follow, and where the clear topcoat has gone completely, the matt finish underneath matches exactly the interior finish, in texture if not quite colour, the outer surfaces having faded, leading me to believe there was no clear coat of any sort, matt or otherwise used.
And again, assuming M-B knew what they were doing, maybe there is no reason for these areas to be clear-coated as without exposure to UV why would they deteriorate?
That is my guess anyway.
Someone back at Benz must know the proccesses used, we will dig further.
Keep 'em coming.
Chris M.
c107 Colour options for the R/C107 models Mercedes R/C107 1
c107 W114/W115 Colour options Mercedes W114 and W115 0
Styria Colour coded diagram - 6.9 Hydraulics Technical Information 1
S Colour Tune Mercedes R/C107 2
Michel Colour changing car paint - Not what you think Websites and Links 4
BenzBoy Colour schemes Talking Torque 21
Michel Glass colour Mercedes W116 8
Styria Chassis 116 colour chart - paint Articles 16
B WTB: B-pillar trim in bamboo colour Gumtree/eBay/Facebook Listings 2
G What colour for the Crayford wagon? Exteriors and Body Repairs 48
J Colour Choices.... Interiors 9
A 450 SE windsheild wipers - original colour & length? Mercedes W116 6
Michel Love the colour of this 450SEL Gumtree/eBay/Facebook Listings 14
Oversize How to Change Your Coolant Technical Information 22
Michel NEW Track Day Anyone? Change of date -- 7 March 09 Motorsports 14
B W116 gearbox change to either W126 or Supra. Mechanicals 7
300SDude Hubcap question? Mercedes W116 6
mrkozzy Radiator treatment question. Mechanicals 3
G Vacuum advance retard question Mechanicals 2
G Speedo stripes? Dumbest question this week? Interiors 20
Des A question for M110 owners Mercedes W116 6
Des maybe the "obvious question" for the day Talking Torque 2
Des Question(s) for BenzBoy and Michel Talking Torque 12
Des Question on lights on race cars Motorsports 18
B HVAC Question Mechanicals 0
Des Sump plug question Mechanicals 16
BenzBoy Engine question. Talking Torque 16
Des question on doors Exteriors and Body Repairs 15
