CIS Fuel Distributor Rebuild
Thanks Styria i am sure a lot of members will find this information very usefull. I cannot use it as i removed evey part of the Bosch injection system from my motor . Geoff :)
c107 Old Fuel Mechanicals 24
A fuel tank Mechanicals 3
