As a rule, those relays located beneath the dash are perfectly reliable. However,, when they commence to malfunction by invariably failing to function IMMEDIATELY, that innocuous looking little switch can set you back about $130.00, fifty less from the after-market people - if they've got them in stock.
Simple fix is to open up the switch, clean up the points and bend them enough to have about 8thou clearance. Five minutes work ! Regards Styria
