Air con drain
More threads by aussie 6.9
aussie 6.9
western nsw
When the AC is on in my 6.9 I get a drip of water on the drivers side footwell. Have checked the drain pipes and can only find a drain on the passengers side. Is there one on the driers side.?
daantjie
Vancouver, Canada
Might be your expansion valve sweating and dripping down? Unlikely as they are covered in tar tape from the factory, but worth a gander methinks.
I believe there are 4 drain holes across the front and you may need to lift the carpet around the transmission tunnel to find them.
Four drain tubes in my SL on Drivers side. Blow out the blockages with compressed Air from under the car..... Gently!
S Air Con mystery Articles 24
S Air Bags Articles 5
Oversize Restrictive Air Filter Assemblies Mechanicals 50
J Aux Air Valve Mechanicals 2
motec 6.9 1954 Packard Caribean Con Talking Torque 5
A bent con rod Mechanicals 1
Michel Battery Drain Mechanicals 52
