Hi,
As part of an engine revamp, I've had to remove the intake manifold.
I reinstalled the manifold last week, ran the engine, only to find some coolant leaks from the coolant ports into the cylinder heads.[V]
This afternoon, I managed to fully remove the intake manifold from the car, again. On the LH bank, where the two coolant leaks were, I have noted that the gasket has been compressed at the top, but the lower area remains only slightly compressed. Problem areas have been marked in the images.
See below:
Image 1
Image 2
The overall situation:
Image 3
Image 4
The other issue is the EGR pipe. It is a constant PITA and I still have not worked out how to remove/install the manifold without interferance. Surely there is a way around this? So far I have only been able to get it to clear by chance.
See below:
Image 1
Image 2
Image 3
Image 4
