Fuel system repairs
I can definitely recommend Ken Airs for changeover, reconditioning, or repairs to fuel distributors, warm up regs and injectors etc. From memory they can even supply Bosch parts (choke slides, fuel pumps etc) far cheaper than genuine items. You may need to supply the part number to ensure you get the right ones. I have a feeling they can even do injector pumps for 6.3s and maybe even diesels. :):)
Please utilise their services as these repairers are becoming very hard to find and we don't want them to disappear altogether....
Ken Airs Petrol Injection Services P/L
Louie Binios - MD
5-9 Baillie Street, North Melbourne, Vic., 3051
Ph (03) 9329 7559
c107 Old Fuel Mechanicals 24
A fuel tank Mechanicals 3
Oversize Cooling System Maintenance Mechanicals 10
